PDA
View Full Version : Tile Forum/Advice Board
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164
  1. Welcome
  2. newbie
  3. Waterproof foot tub
  4. Grout stuff?
  5. Fancy Stuff
  6. pictures?
  7. Leaky Shower
  8. Swanstone anyone?
  9. Thinset or Slurry
  10. Saltillo on elevated - exposed deck
  11. roll-in shower?
  12. Hey There!
  13. Install shower before tiling??
  14. hello
  15. Grab Bar
  16. Mud-bed! Keeping me awake!
  17. wire mesh
  18. Questions on tiling
  19. Making Slibowitz (licquor)
  20. Ecomonics of mud vs. cement backer?
  21. Sealed Granite?
  22. Shower Pan Re-Do
  23. Covering brick fireplace
  24. tile shelf
  25. tile/wood transition
  26. tile repair
  27. cottage cheese ceilings
  28. tile on concrete with movement joint
  29. Meet a Mud Man
  30. saltillo Tile
  31. Newbie homeowner
  32. Tile shower enclosure
  33. Threads being moved
  34. Slab floor prep, after vinyl removal
  35. Tile Layout on Diagonal
  36. Grout sealer?
  37. Vinyl Tile Removal - HELP !!!!!
  38. trip to stone fabrication class
  39. The wife really wants marble tile, but . . .
  40. Marble is cracking
  41. Bleached Grout
  42. Another tile/wood transition question
  43. Wood left in slab.
  44. Tiling bathroom counter
  45. Wood Left in Slab Part 2
  46. Steam Shower
  47. Shoul we pull up vinyl linoleumn flooring?
  48. Pulling up vinyl linoleumn?
  49. Crack in Slab
  50. quarry on a porch
  51. Any thoughts on Semco for use on cracks in slab?
  52. Tile around bathtub and in shower
  53. Small hexagon bathroom tiles
  54. Preparing floor for ceramic tile
  55. Tile question for basement floor
  56. tile over formica
  57. Shower Caulk
  58. Prefab Shower Pan
  59. Grouting large jobs?
  60. Is there a market out there for plastic wall tiles?
  61. Tile on a screen deck porch?
  62. Ready to grout
  63. Tile installation
  64. quary tile questions
  65. Shower Re-Do As Meditation
  66. cracked tiles and expoxy grout
  67. grout problem
  68. CRACK ISOLATION
  69. Family fun night
  70. Tile over a concreat slab
  71. Installing a shower
  72. Thank you already!
  73. Tub -> Shower stall conversion
  74. Thin Set on a riser.
  75. Where do you buy tile?
  76. Removing Tile - Help!
  77. shower pan
  78. Porcelain Tile Shower
  79. Concrete prep.
  80. No Bull Nose Tiles!
  81. TO kalford
  82. Grout lines and layout.
  83. Slab prep and questions
  84. cleoantony
  85. Painting over ceramic tiles
  86. Bathroom Remodel/Americast Tub
  87. Sunken Living NO BULL NOSE
  88. CONSUMER FLOORING GUIDE: INTERNET RESOURCES
  89. We Love Our Insurance Adjustor
  90. Grout Sealant???
  91. Not a tile question. Carport.
  92. So far so Good ? + a Few More Questions
  93. Drilling into floor tiles.
  94. RADIANT HEAT
  95. Scratched Marble Tiles
  96. Shower head
  97. Michael Byrne's Article
  98. Closet flange height for tile
  99. Cracking grout
  100. You guys are fantastic!
  101. GROUT LINE THICKNESS
  102. Removing grout from mosaic tile.
  103. Metal Shower Stall
  104. installing shampoo niche in shower
  105. Uneven backerboard
  106. Irregular Border
  107. Question on Bonsal niches
  108. marble floor
  109. Shower HELP!
  110. FOLLOW UP ON BACKER BOARD
  111. What size tile?
  112. epoxy grout
  113. Cutback revisited
  114. Another thing
  115. Painting Already Installed Tiles
  116. Answers and questions
  117. Grout vs Versa Bond (OOPS) ?
  118. Dusting the grout
  119. RESPONSE TO JOHN'S LATEST
  120. Tile / Carpet Transitions
  121. Lining window jambs with CBU
  122. alternative to tile showers
  123. Grout Manufactors
  124. "Better-Bench" shower benches
  125. Tile on concrete
  126. Difficulty of different Square Patterns
  127. Another Novice
  128. New wall tile over old dried mortar
  129. Installation of 18x18
  130. CBU vs Greenboard in bathrooms
  131. Remove and Reuse
  132. Bud is in charge
  133. CBU Woes
  134. Help please
  135. Help with a Shower Base
  136. T-shaped tile spacers
  137. ceramic over laminate
  138. installing slate tile
  139. Shower Confusion
  140. Screw Heads and Hardibacker
  141. Saltillo Tile?
  142. How far down should CBU go in a shower?
  143. Librarian Tilesetters?
  144. 2 different thin sets?
  145. hello again
  146. Edge treatment for wall tile
  147. Bathroom/kitchen tile/stone installation
  148. tile and radiant floor heat
  149. GROUT
  150. Substitute for plywood as an underlayment?
  151. slope on shower curb
  152. Starting off right...
  153. Trying to cut round cornor
  154. Asbestos Linoleum
  155. Tile Backsplash and Laminate
  156. I'm a Tilesetter!
  157. Sealing Tile
  158. Cutting Porcelain Tile
  159. Sloped Floor and Curb
  160. preparing concrete for tile
  161. Grout scratched my tile,,, Now What???
  162. Flooring options
  163. The Big One
  164. When to seal grout
  165. hairline cracks in grout
  166. porcelin tile
  167. Affordable alternatives for countertop material?
  168. caulk or grout?
  169. Help, quick!
  170. tile on a cracked slab
  171. removing old shower drain
  172. Installing glass block window in shower
  173. ceramic floor tile layout
  174. grout
  175. Thinset for Dal-Tile Porcelain?
  176. frosted glass tile
  177. Building Custom Bathtub & Shower
  178. Waterproofing membrane
  179. remodeling tile over plywood help!!!!
  180. Help...Need Quick Turnaround Time
  181. ceramic tile gone bad
  182. removing cracked tile
  183. Laying Slate
  184. Starting Basement Complete New Shower Addition.
  185. Will it last?
  186. Tile adhesive or thinset?
  187. Grout, Am I doing it wrong? HELP ! ! !
  188. sound proof pergo under tile???
  189. porcelain tile
  190. making grout consistent color across room
  191. Painting tile
  192. Tile vs. Marble
  193. tile under appliances?
  194. cutting tiles around drain
  195. Countertops
  196. Saltillo tiles...
  197. Shower drain
  198. particle board over 2x6 tongue + grv
  199. Another Grouting Question
  200. Sealing framework behind vapor barrier?
  201. Custom tub/shower instructions
  202. Cement Backer Board?
  203. I think I goofed
  204. I just read a post that mention concrete and tile
  205. Modern day shower enclosures
  206. PVC Shower Pan
  207. Wall and floor tear off and replacement
  208. more radiant heat
  209. Rubber flooring and wind-generated electricity
  210. Ceramic floor tiling, very beginner questions
  211. help with unlevel travertine floor
  212. thanks john bridge!
  213. Novice Tiler
  214. Ceramic Tile Entryway
  215. Really noveice tiler!
  216. Blanke Edge trims; butt or leave space for grouting?
  217. HELP!! I need grout help
  218. Laying marble over tile
  219. Is it practical to remove tile from concrete?
  220. Sites for tile layout ideas?
  221. subfloor--fir or spruce, does it matter?
  222. HELP I need Help removing cured grout too
  223. wall, floor tile removal
  224. Breaking sharp edges on Porcelain
  225. Custom shower design questions/problems???
  226. Ceramic Tile Removal
  227. Tiling over plywood question
  228. Tile abuuting hardwood
  229. embedding hardiboard in shower deck mud???
  230. Making Mosaic Marble Dining Tops
  231. Ditra
  232. BEER- question about Ditra $
  233. Standard height for wall tiles????
  234. Grouting ceiling tile.
  235. installing different thickness tiles
  236. Laying Wonderboard on Slab?
  237. Buying tile online
  238. Chipping ceramic tile's glaze as Diamond wheel finishes cut thru.
  239. Tile grout
  240. Tile over paneling
  241. Vapor Barrier in showers?
  242. tile under/around toilet?
  243. Ditra and tile I!!
  244. Getting started...
  245. bud cline !!
  246. Caulk/Grout question
  247. Colouring Tile Grout
  248. bathroom remodel
  249. Kitchen floor replacement
  250. Ultimate "Tiling for Dummies" guide
